smartstart wires white/gray
mjkraffert
Member - Posts: 7
Posted: December 20, 2014 at 7:57 PM / IP Logged
I've searched the forums and can't figure out how to install my SmartStart module. I have a DSM-200 and a Viper 5706V installed on my 2003 F150. The 5706 works fine, and everything functions correctly. The instructions I've found online for the DSM-200 mention a white loop and a brown loop. My module doesn't have either loop, but it does have a white wire and a gray wire coming out of it. These aren't part of either connector. What are these for, and how do I hook them up? Thanks.
pentavolvo
Copper - Posts: 241
Posted: December 20, 2014 at 8:10 PM / IP Logged
Did you hook up positive and negative on smart start? What port did you plug into on the remote start
What are the communication lights on smart start doing
mjkraffert
Member - Posts: 7
Posted: December 20, 2014 at 9:10 PM / IP Logged
Plugged into the D2D port and hooked up the power wires. The orange LED is on steady. No green LED at all.
vipercon99
Member - Posts: 8
Posted: December 21, 2014 at 12:49 AM / IP Logged
Ground the gray wire
pentavolvo
Copper - Posts: 241
Posted: December 21, 2014 at 8:54 AM / IP Logged
Don't use the d2d port use the bit writer port on the end of the 5706 and don't ground the wires
Posted: December 21, 2014 at 9:23 AM / IP Logged
X 2 with Pentavolvo, ignore the white and grey wires and us the black bitwriter port.
josetizapan
Posted: December 22, 2014 at 7:41 PM / IP Logged
I am also having the same issue i've installed the PS3001 in my truck and the amber light is solid but it is not reciving any commends from my app on the phone. I've called DEI and they told me i have to be a dealer to get help from them.
99 GMC Yukon Denali
7in touch screen head unit
9in headrest monitors
15in Kove Armageddon
MTX 1000xd
