Viper 4205, 93 Dodge Spirit
hawkeye
Member - Posts: 8
Posted: January 29, 2015 at 8:13 PM / IP Logged
Hello
I am having an issue with getting my remote start to program I cannot get the led light on the brain to power on when I press the valet button. my car is a 93 dodge spirit
Here is my setup im not sure if im missing something
H1/1 LIGHT GREEN/ not connect
BLACK FACTORY ALARM DISARM not connected
H1/2 GREEN / WHITE FACTORY REARM not connected
H1/3 YELLOW (+) IGNITION OUT (TO ALARM) not connected
H1/4 WHITE/ BLUE (-) ACTIVATION INPUT not connected
H1/5 ORANGE (-) GROUND WHEN LOCKED* not connected
H1/6 BROWN (-) HORN OUTPUT connected
H1/7 RED / WHITE (-) TRUNK RELEASE OUTPUT* not connected
H1/8 BLACK GROUND connected
H1/9 WHITE (+/-) LIGHT FLASH Not connected
4-pin satellite harness wiring daigram
1 BLUE STATUS OUTPUT Not connected
2 ORANGE (-) ACCESSORY OUTPUT not connected
3 PURPLE (-) STARTER OUTPUT not connected
4 PINK (-) STARTER OUTPUT not connected
Heavy gauge relay wiring diagram
1 PINK (+) (30 AMP) OUTPUT TO IGNITION CIRCUIT connected
2 PURPLE (+) (30 AMP) OUTPUT TO STARTER CIRCUIT connected
3 ORANGE (+) (30 AMP) OUTPUT TO ACCESSORY CIRCUIT Not connected yet
4 RED (+) (30A) HIGH CURRENT 12 INPUT
5 PINK/WHITE (+) PROGRAMMABLE OUTPUT FOR ACCESSORY OR IGNITION not connected
6 RED (+) (30A) HIGH CURRENT 12V INPUT connected
Door lock harness, 3-pin connector
1 BLUE (-) UNLOCK OUTPUT Not connected
2 EMPTY NOT USED
3 GREEN (-) LOCK OUTPUT Not connected
Remote start harness (H2) wiring diagram
H2/1 BLACK/ WHITE (-) NEUTRAL SAFETY SWITCH INPUT connected to ground
H2/2 VIOLET/WHITE TACHOMETER INPUT WIRE connected
H2/3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE connected
H2/4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE not connected yet
H2/5 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT not connected
Connected
tedmond
Gold - Posts: 4,610
Posted: January 29, 2015 at 8:29 PM / IP Logged
what are you trying to program exactly ? Since its a remote start i will assume tach programming?
Ted
Compustar Expert
hawkeye
Member - Posts: 8
Posted: January 29, 2015 at 9:55 PM / IP Logged
I am trying to program the remotes so they start the vehicle. I'm not sure why its not working. The led in the module doesn't come when i press the valet button and run through the remote program, so I am not sure what I am doing wrong.
hawkeye
Member - Posts: 8
Posted: January 29, 2015 at 10:32 PM / IP Logged
Also this is my first install of a remote start so I am just wondering if I have something thats not connected that needs to be?
tedmond
Gold - Posts: 4,610
Posted: January 29, 2015 at 10:54 PM / IP Logged
double check your ignition to ensure it is infact an ignition wire.
Ted
Compustar Expert
hawkeye
Member - Posts: 8
Posted: January 29, 2015 at 11:09 PM / IP Logged
Ok will do! also on primary harness there was a 12v wire on the older style harness where as this I dont see one should there be 12v connected to this harness? also is the yellow wire of this just another ignition wire that doesnt need to be hooked up?
Primary Harness (H1), 9-pin connector
H1/1 LIGHT GREEN BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT
H1/2 GREEN / WHITE (-) 200mA FACTORY ALARM REARM OUTPUT
H1/5 ORANGE (-) 500mA GROUND WHEN LOCKED/ANTI-GRIND OUTPUT
H1/6 BROWN (-) 200mA HORN OUTPUT
H1/7 RED / WHITE (-) 200mA TRUNK RELEASE OUTPUT*
H1/8 BLACK GROUND INPUT
H1/9 WHITE (+/-) LIGHT FLASH OUTPUT
hawkeye
Member - Posts: 8
Posted: January 30, 2015 at 10:21 PM / IP Logged
Ok, I checked the ignition and I am getting 12v at the pink wire of the harness with key turned to the last click. I also checked the starter (12v) when started and both the high current 12v inputs. all check out good. I have a good ground as well.
Is there something I am missing?
tedmond
Gold - Posts: 4,610
Posted: January 30, 2015 at 11:33 PM / IP Logged
make sure the wire does not loose 12v when starting.
Ted
Compustar Expert
banthonyb71
Member - Posts: 32
Posted: February 01, 2015 at 1:02 AM / IP Logged
What is your process of programming? are you turning the ignition on, tapping the valet button once then pressing and holding?
hawkeye
Member - Posts: 8
Posted: February 02, 2015 at 12:23 PM / IP Logged
Turns out it was a defective module. It was a refurb and was defective out of the box. I got a brand new one on the exchange and it works like it should.
Thanks for your help guys!
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
