05 Durango, Viper 4105v and DB-ALL2
adkinsc
Posted: February 22, 2015 at 12:30 PM / IP Logged
I have a Viper 4105 and DB-ALL2 coming. I've been reading up before they get here. I have a question about the door locks. The instructions I've found say to use a -pulse and diodes with 2 relays. Is it possible to use the factory door lock relays? Also I'm not positive whether or not I have the sentry key anti theft feature. The durango came with two keys that have the lock/unlock and panic buttons, one of which must not be programed because it doesn't function. I removed the ic board from inside the fob and the key still started and allowed it to run so I'm thinking there isn't any anti theft. Any other heads up would be appreciated if anyone has anything I should look out for. Thanks in advance
tedmond
Gold - Posts: 4,610
Posted: February 22, 2015 at 8:23 PM / IP Logged
if you were hardwiring your locks, you would need 2 relays, resistors and a negative trigger from the remote start.
HOWEVER- you are using a convenience module (DBALL2) + built in immobilizer bypass. No need for relays as its controlled by the vehicles network.
You will require one additional relay for the second acc wire. Other than that very basic/easy install.
Ted
Compustar Expert
adkinsc
Posted: February 23, 2015 at 5:26 AM / IP Logged
Oh, ok. I ran across a couple threads about installs on other vehicles and reading the dball instructions that kind of made me think that but I still wasn't sure. Man, technology has came a long way since the last install I did. Thanks for the clarification Ted.
