2007 ford fusion
ricardoboston
Copper - Posts: 268
Posted: February 26, 2015 at 6:02 PM / IP Logged Link to Post Post Reply Quote ricardoboston
hi i recently have a remote start installed an 2007 ford fusion and the remote starter works great but this car has digital heat and ac the thing is when the car start with the remote start the heat won't work even if he start the car with the key won't work either unless you turn it on manually so anyone knows what i should do to try to help him or it its normal ? cause the guy always has to go to the car in the morning to turn the heat on manually ,thanks
tedmond
Gold - Posts: 4,610
Posted: February 26, 2015 at 6:55 PM / IP Logged Link to Post Post Reply Quote tedmond
Holy run on sentence. Might want to use some punctuation there...
Two possible fixes:
1) Follow TSB 09-20-1
Replace EATC Module to:
8E5Z-19980-A     EATC Climate Control Module - Less Heated Seats
8E5Z-19980-B     EATC Climate Control Module - With Heated Seats
2) Wire a relay to trigger the dash switch, use a pulse after start depending on your unit.
Ted
Compustar Expert
Posted: February 27, 2015 at 6:40 AM / IP Logged Link to Post Post Reply Quote howie ll
Trypoweringupalloftheignitionleadsorgetthecustomertoturnitonthenightbefore.
My spell check didn't like that very much.
