Window Module issue/troubleshooting
lbfire20
Posted: March 23, 2015 at 7:58 PM / IP Logged Link to Post Post Reply Quote lbfire20
How are you guys, think this is my first time posting cause i have always been able to find the answer on here searching but i cant on this one.
I have a 1998 Chevy tahoe 2dr, installed in my tahoe is the audiovox prestige Model APS-997C. I just purchased and installed a Scytek - ACCWR-8-4 - 4 Window Roll Up 2 Window Up/Down Module With Auto Temperature And Remote Manual Ventilation
I have all the wires hooked up to correct window wires, I cut the black white jumper for 2 window up/ down mode. I hooked up just the yellow wire to the Orange Wire: 300mA (-) Ground When Armed Output. after all was said and wired I rolled down both windows and when i went to take key out of ignition passenger side window went up the minute i turned key to off.
I then said let me go inside and read up on this, started car rolled up drivers window cause it didnt go up, once i turned off the key the drivers window auto rolled down.
disconnected yellow wire and all works fine with switches. ground the yellow wire to test and same thing happens, constant ground and windows go nuts.
read up and it says the auto down window function must be bypassed, i am assuming that might be it but i do not see any relay for that anywhere, the wires go straight from switch motor. the wiring diagram i have for truck shows the relay in the switch.
any help or suggestions you guys have would be great. I am also exhausted after all this so i hope this makes sense and i didnt forget anything
Mike
