2010 GTI Remote Start
no1tmorrow
Member - Posts: 9
Posted: March 24, 2015 at 7:11 AM / IP Logged Link to Post Post Reply Quote no1tmorrow
I am putting a Dball2 in my car and have a Pass-4 Omega that I would like to use instead of a key wrap. The problem is figuring out how to hook up the blue wire. Anyone happen to have experience or an idea?
12V = Just hook to 12V, no big deal
Keysense = don't think I need
blue wire is negative ignition. Well that is not an option on the Dball2. there is only a positive ignition
Thom
tedmond
Gold - Posts: 4,610
Posted: March 24, 2015 at 8:39 AM / IP Logged Link to Post Post Reply Quote tedmond
if you are using the DBALL 2 as a stand alone, on the blue connector of the dball ground BROWN / red. dball yellow/red to omega blue negative ignition.
Ted
Compustar Expert
no1tmorrow
Member - Posts: 9
Posted: March 24, 2015 at 9:17 AM / IP Logged Link to Post Post Reply Quote no1tmorrow
Not as a stand alone exactly. Will be adding a Code Alarm CA4054.
Blue Connect
BROWN / red = take to ground?
Yellow/red = blue
wires 10/11 on blue connector?
Thanks so much for your help!!!
tedmond
Gold - Posts: 4,610
Posted: March 24, 2015 at 10:22 AM / IP Logged Link to Post Post Reply Quote tedmond
correct. however if you are using a remote start unit, the unit has a status or ground when running output. connect the blue neg ignition to the remote start instead.
Ted
Compustar Expert
no1tmorrow
Member - Posts: 9
Posted: March 24, 2015 at 5:00 PM / IP Logged Link to Post Post Reply Quote no1tmorrow
If I connect the blue neg ignition to the remote starter then do I not use Yellow/Red or BROWN / Red on the dball?
Does the Pass-4 just use BROWN / red and yellow/red to switch a ground and power the Pass-4?
Thanks again Ted, I really appreciate it.
tedmond
Gold - Posts: 4,610
Posted: March 24, 2015 at 5:20 PM / IP Logged Link to Post Post Reply Quote tedmond
the dball yellow/red and BROWN / red will not be used. just connect the pass-4 directly to the remote start unit.
the dball can control the pass-4 as well, but isn't necessary. Yes, the dball simply provides a ground.
Ted
Compustar Expert
no1tmorrow
Member - Posts: 9
Posted: March 28, 2015 at 8:49 PM / IP Logged Link to Post Post Reply Quote no1tmorrow
Hello,
I finished my install today. Thought I got it working but. When I remote start it. It start, runs for a second and then dies. Screen say Immobilizer Active. Is the key in the box, Omega Pass-4 the problem or maybe the dball2? Don't really know where to start.
Thanks in advance.
Thom
Posted: March 29, 2015 at 2:38 AM / IP Logged Link to Post Post Reply Quote howie ll
Change the key in box for a 555U and follow the instructions for European cars by ignoring the loop.
Done loads of VW/Audi/BMW using that method.
tedmond
Gold - Posts: 4,610
Posted: March 29, 2015 at 6:18 AM / IP Logged Link to Post Post Reply Quote tedmond
program tach
Ted
Compustar Expert
Posted: March 29, 2015 at 6:21 AM / IP Logged Link to Post Post Reply Quote howie ll
Not tach Ted, immobiliser bypass not working, you can also do the key wrap with this car, at least according to Xpresskit instructions for the DB-ALL.
