Viper 5706V and DB-ALL2
asutherland92
Posted: April 27, 2015 at 12:26 PM / IP Logged Link to Post Post Reply Quote asutherland92
Hey guys, I'm going to be installing a Viper 5706V remote start with alarm in my car, and I will be using the Expresskit DBALL2. I want to make sure I have all the connections I need figured out...
     VIPER CONNECTIONS
H1/1     (+)12V CONSTANT INPUT        (+)12V CONSTANT
H1/2     (-) CHASSIS GROUND  GROUND TO CHASSIS
H1/3     (+) SIREN OUTPUT HOOK TO (+) SIREN
H1/4     PARKING LIGHT ISOLATION N/A
H1/5     PARKING LIGHT OUTPUT        N/A
H1/6     (-)500 mA GROUND WHEN ARMED N/A
H2/1     FLEX RELAY CONTROL OUTPUT      N/A
H2/2     (-) NEUTRAL SAFETY INPUT       GROUND TO CHASSIS
H2/3     (-) 2ND STATUS/REAR DEFOGGER   N/A
H2/4     (-) OEM ALARM DISARM N/A
H2/5     (-) TRUNK RELEASE OUTPUT       N/A
H2/6     (-) DOOR TRIGGER INPUT     GREEN N/A
H2/7     (-) DOME LIGHT SUPERVISION OUT N/A
H2/8     (-) HORN HONK OUTPUT N/A
H2/9     (-) STATUS OUTPUT N/A
H2/10     (-) IGNITION 1 OUTPUT N/A
H2/11     (-) AUX 3 OUTPUT N/A
H2/12     (+) DOOR TRIGGER INPUT N/A
H2/13     (-) AUX 1 OUTPUT N/A
H2/14     (-) AUX 2 OUTPUT N/A
H2/15     (-) AUX 4 OUTPUT N/A
H2/16     (+) BRAKE SHUTDOWN INPUT       BRAKE SWITCH
H2/17     (-) HOOD PIN INPUT TO HOOD PIN
H2/18     (-) STARTER OUTPUT N/A
H2/19     (-) TRUNK PIN/INSTANT TRIGGER N/A
H2/20     (-) DIESEL WAIT TO START INPUT N/A
H2/21     (-) REMOTE START/TURBO TIMER   N/A
H2/22     (-)200mA ACCESSORY OUTPUT      N/A
H2/23     TACHOMETER INPUT N/A
H2/24     (-) OEM ALARM ARM OUTPUT       N/A
H3/1     IGNITION 1 INPUT/OUTPUT     PINK   IGNITION WIRE
H3/2     FLEX RLAY (+)12V INPUT (FUSED) 12V CONSTANT
H3/3     ACCESSORY OUTPUTN/A
H3/4     STARTER OUTPUT     N/A
H3/5     STARTER INPUT     N/A
H3/6     IGNITION 1 (+)12V INPUT(FUSED) 12V CONSTANT
H3/7     FLEX RELAY OUTPUT IGNITION WIRE
H3/8     FLEX RELAY INPUTN/A
H3/9     ACCESSORY/STARTER RELAY(FUSED) 12V CONSTANT
H3/10   EMPTY
NO PINS ON DOOR LOCK HARNESS USED
     DBALL2 CONNECTIONS
12/1     RAP OFF   TO DRIVER DOOR SENSE TRIGGER
12/3     DOOR STATUS OUTPUT      N/A
12/4     TRUNK STATUS OUTPUT     N/A
12/5     TACH OUTPUT N/A
12/6     BRAKE STATUS OUTPUT     N/A
12/7     ACCESSORY OUTPUT     TO ACCESSORY WIRE
14/1     SINGLE WIRE CAN     TO PIN 1 ON OBD PORT
14/10     IMMO CONSTANT (CAR SIDE)    TO CAR SIDE OF IMMOBILIZER WIRE
14/11     IMMO CONSTANT (CONN. SIDE) TO CONNECTOR SIDE OF IMMO. WIRE
14/13     (+)12V          N/A
14/14     (-)GROUND  N/A
     CONNECTOR 10 NOT USED AT ALL.
     CONNECTOR 4 HAS D2D CABLE, CONNECTED TO D2D PORT ON VIPER.
asutherland92
Posted: April 27, 2015 at 12:27 PM / IP Logged Link to Post Post Reply Quote asutherland92
Forgot to add, car is a 2010 Chevy Malibu LS
dairyboy3
Copper - Posts: 52
Posted: April 27, 2015 at 1:04 PM / IP Logged Link to Post Post Reply Quote dairyboy3
Use D2D follow the DBALL2 install guide this car is easy. You wont have to hard wire the brake wire the DBALL2 takes care of that for you. You only have to do it on some Saturns. You can get 12v constant at the BCM. Only other wires you have to hook up from the 5706 are ignition, ground, hood pin and parking lights. The DBALL2 takes care of all other connections.
dairyboy3
Copper - Posts: 52
Posted: April 27, 2015 at 1:05 PM / IP Logged Link to Post Post Reply Quote dairyboy3
Forgot you will also have to ground the neutral safety wire on the brain.
Posted: May 16, 2015 at 4:15 AM / IP Logged Link to Post Post Reply Quote howie ll
Dairyboy sorry to be a pain but don't forget the siren Viper 5706V and DB-ALL2 -- posted image.
