Most important sensors to add to factory car alm
cz eddie
Member - Posts: 20
Posted: May 07, 2015 at 7:45 PM / IP Logged Link to Post Post Reply Quote cz eddie
So for various reasons, I've decided to retain my factory car alarm on my 2015 Kia Optima with smart key. Now I need to focus on beefing up this alarm. As far as I know, it simply monitors the doors/trunk. Opening one of these up while alarmed will set the car horn beeping and disable the ignition.
I'm thinking of adding the following to the door trigger so that when one is set off, it will fool the alarm into thinking the door has been opened and set off the alarm.
1) Window breakage sensor.
2) Tow sensor.
3) Interior movement sensor (I tend to leave windows open).
Am I missing anything really important?
Is there a quality difference between the various sensors I might find on Amazon Prime?
Posted: May 08, 2015 at 6:56 AM / IP Logged Link to Post Post Reply Quote howie ll
Interior movement sensor.
I''m not sure but you may have compatibility problems adding ANY aftermarket sensor.
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
