2015 Nissan Rogue Rap shut down
mpe235
Copper - Posts: 90
Posted: July 05, 2015 at 11:58 AM / IP Logged Link to Post Post Reply Quote mpe235
I installed a crime stopper RS2-G3 and evo-all in my 2015 Nissan Rogue. It has a regular key. Everything works as it should except the rap shutdown. I connected everything according to the evo-all instructions. The light blue wire is going to the driver's door pin wire at the bcm. If i test the wire with a meter it does not ground after shutdown. I also tried connecting the orange wire from the remote start to that pin instead. I configured option 12 to arm after remote start abort but I still don't get a ground on that wire. I did test the wire at the bcm also. I definitely have the correct wire there. Any ideas on what i could be missing? I don't see anything in the evo-all options that would change the function of that wire. I am using firmware 72.19.
Nissan Master Tech.
mpe235
Copper - Posts: 90
Posted: July 08, 2015 at 4:59 PM / IP Logged Link to Post Post Reply Quote mpe235
Just in case anyone runs into this problem, it is an issue with firmware 72.19. 72.18 works fine.
Nissan Master Tech.
