Viper 5706 No Door Lock\Unlock
tron77
Posted: July 12, 2015 at 2:05 PM / IP Logged Link to Post Post Reply Quote tron77
Hi crew,
 I have fitted my Viper 5706v (Basic- alarm only, i intend to do remote start some other time) into my Nissan Patrol GU3, but are having troubles with door lock\unlock not working.
Initially a Vision VAE 318-1800 alarm was inplace,,, So I decided on a changeout to a new Viper. Everything is working as intended apart from door locking\unlocking,,, going from the Vision VAE318 wires already installed & the wire diagram,,, show that remote locking was pins 30 Green\Yellow - Lock "C" & Blue\Yellow pin 33 Unlock "C". I wire these to resemble what was initially installed on the Vision VAE318 as to resemble to the VIPER (Door Lock 3 pin connector),,,,,PIN30= GREEN (-) 500mA LOCK OUTPUT & PIN33= BLUE (-) 500mA UNLOCK OUTPUT...BUT NO go. Any ideas would be appreciated.
Viper 5706 No Door Lock\Unlock -- posted image.Viper 5706 No Door Lock\Unlock -- posted image.
tron77
Posted: July 12, 2015 at 7:43 PM / IP Logged Link to Post Post Reply Quote tron77
Awesome problem solved...
Here is a pinout of the keyless entry module for anyone wanting to know, I removed the module altogether and spliced\soldered into the wires shown in the picture. Everything you need to replace it is right here, the BLACK/ red and BLACK / YELLOW wires can be used to trigger the door lock relay (negative trigger) and if you have moved the blue and blue/red wires to the door lock relay it will work just fine.
[IMG]uploads/B35_plug#2.jpg[/IMG]
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
