2014 Camry XLE V6 PTS
wyciwug
Copper - Posts: 158
Posted: October 16, 2015 at 12:41 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello
I heard Idatalink bypass Ads-ALCA TL6 alone can be installed and use as remote start to start the car using factory remote. Is that correct? Does anyone have a diagram for it?
dcd
rs specialist
Copper - Posts: 175
Posted: October 16, 2015 at 6:26 PM / IP Logged Link to Post Post Reply Quote rs specialist
http://fortin.ca/download/13981/evo-all_toyotaavalon2013_push_d20140311_standalone.pdf
This is for the EVO-ALL and since you do not need to have a login to configure the module (you will still need the FLU-100.2 if you want to change the options) it will be a better choice for end users.
I have used both and they are both solid installs. If you want the ADS guide just look it up on their website.
wyciwug
Copper - Posts: 158
Posted: October 17, 2015 at 5:47 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hi
I did it. I flashed it and installed the bypass only. The car is now started with factory OEM remote :))
dcd
wyciwug
Copper - Posts: 158
Posted: November 08, 2015 at 1:23 PM / IP Logged Link to Post Post Reply Quote wyciwug
I just bought an RF kit from compustar RF-2W704-SH. I plugged in the data port on the brain of idatalink Alva. Nothing happens when I press any button on the new remote. The new led remote has the word "call" on it. What does that mean? And how do I make this work? Thanks
dcd
bs1d3
Copper - Posts: 58
Posted: November 09, 2015 at 3:05 PM / IP Logged Link to Post Post Reply Quote bs1d3
Did the remote kit have the RF decoder with it? Did you program the remotes to the vehicle?
wyciwug
Copper - Posts: 158
Posted: November 09, 2015 at 3:09 PM / IP Logged Link to Post Post Reply Quote wyciwug
This is what I got
Whats Included:
1x 2W704R-SH Remote (2-way LCD)
1x 1WSHR Remote (1-way)
ANT-2WSH Antenna
Antenna Cable
There is also a little loop wire with one end connector with 2 pin. I have no clue what it is. I can send you a picture through text if you have a phone #
I guess I have to buy the decoder? And I have not program the remotes yet.
dcd
bs1d3
Copper - Posts: 58
Posted: November 09, 2015 at 3:28 PM / IP Logged Link to Post Post Reply Quote bs1d3
The remotes don't come pre-programmed on that one, so they will need programmed first. It also says the ft-d100 is required and I know some of the remotes didn't come with it.
wyciwug
Copper - Posts: 158
Posted: November 09, 2015 at 3:30 PM / IP Logged Link to Post Post Reply Quote wyciwug
ohhh ok, I will go look for ft-d100 now. THanks
dcd
bs1d3
Copper - Posts: 58
Posted: November 09, 2015 at 3:33 PM / IP Logged Link to Post Post Reply Quote bs1d3
$58 online. I'd almost return the remote kit and get one that comes with it.
wyciwug
Copper - Posts: 158
Posted: November 13, 2015 at 7:59 AM / IP Logged Link to Post Post Reply Quote wyciwug
Does anyone have any manual or instruction on the COMPUSTAR RF kit? And maybe for the RF decoder?
dcd
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
