ProStart Remote Car Starter stop working
mgmjtech
Posted: November 15, 2015 at 7:54 PM / IP Logged Link to Post Post Reply Quote mgmjtech
Just replaced my car battery and now my remote starter stop working.
I have a prostart CT-3471 TW on a honda civic (manual transmission)
I was able to get my lock and unlock button working again by
getting into the program mode
ground the grey wire to the metal
turn the key on and off
press and hold the brake pedal
press lock
however, my start remote button still not working. I have seen other forum indicated you have to start the engine in order to program your remote to work again. Please advice how do I reprogram my start button to work again.
http://www.prostartsystems.com/Docs/CT-3471TW_ig_en_h50s40_121105.pdf
shark mobile
Copper - Posts: 83
Posted: November 15, 2015 at 9:34 PM / IP Logged Link to Post Post Reply Quote shark mobile
Try reprogramming the tach...if the locks are working the remote ms are programmed..
Solder, tape, repeat!
mgmjtech
Posted: November 18, 2015 at 7:09 PM / IP Logged Link to Post Post Reply Quote mgmjtech
reprogram the tach and still doesn't work.
i have also reset the module. Is there a specific steps to reprogram the tach?
shark mobile
Copper - Posts: 83
Posted: November 19, 2015 at 7:25 AM / IP Logged Link to Post Post Reply Quote shark mobile
Test the tach wire you tagged using the AC voltage on you DMI and make sure you have the right wire. It should be around 1.3 volts or so but the important thing is that when you press the accelerator it increases. Start by making sure it's right before going further.
Posted: November 19, 2015 at 10:39 AM / IP Logged Link to Post Post Reply Quote howie ll
Test all the fuses, it might have spiked.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
