2006 Ford Fusion parking lights
jas51384
Member - Posts: 32
Posted: November 23, 2015 at 9:59 AM / IP Logged Link to Post Post Reply Quote jas51384
Hi All,
I'm having trouble finding the positive (+) parking light wire to connect my remote start and illumination wire. The wiring diagram on this forum shows: Parking Lights+ gray / YELLOW   +   driver kick or SJB, conn. E, pin 30. While the drivers kick panel has 4 of these wires only 1 showed about 2volts. I don't know what connector E is since I can't find a diagram showing what the SJB plugs are. I don't like using the negative (-) wiring at the switch because it will also turn the headlights on. Any help is appreciated.
Platinum - Posts: 7,827
Posted: November 23, 2015 at 12:51 PM / IP Logged Link to Post Post Reply Quote kreg357
You can find a wire listing and a photo of the SJB connector with the (+) Parking Light wire marked here :
  http://www.readyremote.com/main.asp?make=Ford&model=Fusion
jas51384
Member - Posts: 32
Posted: November 23, 2015 at 3:29 PM / IP Logged Link to Post Post Reply Quote jas51384
Thank you very much for the link.
Tuesday, August 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
