Aps997e omega db all
bat9905
Copper - Posts: 131
Posted: December 05, 2015 at 4:14 PM / IP Logged Link to Post Post Reply Quote bat9905
Just finished this 07 compass but the vehicle is not starting . Originally went wire to wire mode I programmed bypass . When I send command to start ignition comes on like it is attempting but fails to turn over . Anyone have any ideas
bat9905
bat9905
Copper - Posts: 131
Posted: December 05, 2015 at 4:47 PM / IP Logged Link to Post Post Reply Quote bat9905
I should also mention I had it re flashed and went data mode with same results . For both modes I follow directions to the diagram .
bat9905
bat9905
Copper - Posts: 131
Posted: December 05, 2015 at 10:31 PM / IP Logged Link to Post Post Reply Quote bat9905
Someone has to know something . I know we shouldn't assume with wiring but I pulled can h and can l , ignition and mux about 12 " from transponder connector . Could this be the issue ?
bat9905
