installing avital 4103 in 1994 f150
dmichaelsmith1
Posted: January 16, 2016 at 4:07 PM / IP Logged Link to Post Post Reply Quote dmichaelsmith1
Hey guys! I could use some help. I installed an Avital 4103 remote start on my 1994 F150 5.8L. It will start so that's not the problem. But the heater blower does not come on. I tapped into the Grn/Blk and Gry/Yell wires for the accessory wires. But there are 3 total Gry/Yell wires in the ignition switch harness. So I'm not sure I picked the right one.
Also, my door locks will not function either. I tapped into the factory keyless entry wires. I could use some help please!
geepherder
Platinum - Posts: 3,668
Posted: January 16, 2016 at 5:36 PM / IP Logged Link to Post Post Reply Quote geepherder
You need to test the wires with a multimeter. Accessory wires will not have power when the key is in the off position, but will have power when the key is in the accessory position.
You may need to 5-wire: https://www.the12volt.com/doorlocks/page3.asp#5w
