2014 Nissan Rogue, remote start
cneubert42
Member - Posts: 46
Posted: February 07, 2016 at 9:28 AM / IP Logged Link to Post Post Reply Quote cneubert42
I am trying to give a quote for a 2014 Nissan rogue, customer doesn't know if it is the select or not but it does have a standard key with built in fob. She claims it is the 2014 Nissan rogue with the new body style if that helps. anyways I don't see the standard rogue listed as compatible with the DBALL2 on directechs so I am thinking a key wrap would be best. does anyone have a spec sheet for this vehicle and possibly any details about the module? Thanks!
flobee4
Silver - Posts: 585
Posted: February 10, 2016 at 9:47 PM / IP Logged Link to Post Post Reply Quote flobee4
If its a "select" it will say "select" underneath the nameplate rogue on the tailgate(drivers side). If its a left over rogue, there will only be the rogue nameplate by itself.
If its a Rogue Select, it will have a flip key and you will need to do a keywrap.
If its a left over rogue, just follow the guides and firmware for a 2010-2013 rogue, no need to give up a key. I personally use a Evo-all for either generation. Its also an easier install on the 10-13 rogue compared to idata or db-all since you don't have to do the ignition cut(white wire) at that module behind the coin holder. Look at the install guides, you'll see what cut I mean.
cneubert42
Member - Posts: 46
Posted: February 12, 2016 at 10:37 AM / IP Logged Link to Post Post Reply Quote cneubert42
Thanks!
beegbie
Copper - Posts: 341
Posted: February 14, 2016 at 7:05 PM / IP Logged Link to Post Post Reply Quote beegbie
Flobee is wrong here. If it's a select, you will be able to do the install without losing a key. If it's not a select, the customer will need to give up a key. Most are push to start, some have flip keys.
flobee4
Silver - Posts: 585
Posted: February 16, 2016 at 4:10 PM / IP Logged Link to Post Post Reply Quote flobee4
Opps, I had it backwards, sorry. Thanks for looking out Beegbie
cneubert42
Member - Posts: 46
Posted: February 20, 2016 at 10:26 AM / IP Logged Link to Post Post Reply Quote cneubert42
OK I told her it would require giving up the key just to be on the safe side, then if I could get a module to work it would just be a bonus.
