2004 F350 Superduty Powerstroke Remote Start
cowhead
Member - Posts: 6
Posted: April 14, 2016 at 12:55 PM / IP Logged Link to Post Post Reply Quote cowhead
I am looking to install a remote start and security system in my 2004 F350 Powerstroke.   I found a wiring sheet for it but where do I get my Tach signal for my Remote start? Will my diesels High idle kill the remote start? How do I know if I have a GEM Module?   I am pretty good with wiring and can figure most things out.   I do have a question tho when it says for example (Door Unlock Lt Blue/Red -) what is the - vs a + is it grounding out that wire to make an unlock?
I do not think you can name many great inventions that have been made by married men.
cowhead
Member - Posts: 6
Posted: April 14, 2016 at 12:56 PM / IP Logged Link to Post Post Reply Quote cowhead
IRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2004 / Remote Start
12volts yellow & lt. GREEN/ purple   +   ignition harness
Starter green   +   ignition harness
Second Starter N/A
Ignition RED / lt. green or WHITE/ yellow   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW & RED / black   +   ignition harness
Second Accessory blue/lt. green   +   ignition harness
Keysense
Power Lock see notes
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock see power lock notes
Lock Motor pink/black   5wi VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange   5wi VSM
Parking Lights+ brown   +   headlight switch
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +   steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +   steering column
Reverse Light BLACK/ pink   +   fuse box
Door Trigger BLACK/ lt. blue   +   passenger kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer NOT RED / lt. green   ac   any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green   +   brake pedal switch
Parking Brake lt. GREEN/ red   -   parking brake switch
Horn Trigger blue   -   steering column or VSM
Memory Seat 1 BROWN / lt. green   -   memory mod under dr seat
Memory Seat 2 BLACK/ orange   -   memory mod under dr seat
Memory Seat 3 N/A   -
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
davep.
Gold - Posts: 649
Posted: April 14, 2016 at 6:42 PM / IP Logged Link to Post Post Reply Quote davep.
You have a 2004 which does not have a GEM. It has a VSM.
A (+) means that wire, signal, or output is a Positive voltage, measured to ground.
A(-) means that wire, signal, or output is a Negative voltage, measured to ground.
Read your above, it tells you where the tach wire is.
cowhead
Member - Posts: 6
Posted: April 14, 2016 at 8:12 PM / IP Logged Link to Post Post Reply Quote cowhead
Not to complicate your day but what exactly is a GEM and a VSM? Just for curiosity sake.   I also see the section on the Tach now apparently I am blind..   I was looking at getting the Excalibur AL-1860-EDPB is this a good unit? It got good reviews but I just dont want to get stuck with a total POS
davep.
Gold - Posts: 649
Posted: April 15, 2016 at 8:49 AM / IP Logged Link to Post Post Reply Quote davep.
Not familiar with Excalibur. Can't comment.
Generic Electronic Module and Vehicle Security Module. The GEM performs the functions of a Body Controller. The GEM was 99-01. The VSM in 01-07 doesn't perform as many functions as the GEM did. A lot of the GEM's functions are now performed by the instrument cluster. You can tell if an early Super Duty / Excursion is GEM or VSM by looking at the odometer. The old dial analog is a GEM, and the electronic digital odometer is a VSM.
The electrical systems and layouts in the SD's have undergone several major redesigns during its evolution. I participate on Powerstroke forums, mostly in the 7.3 section because that's what I own. When the guys don't give their year, it's tough to advise them because there are significant differences between them.
