2012 dodge Ram 1500 st, Viper 5906
ttimms20
Member - Posts: 43
Posted: May 26, 2016 at 12:54 AM / IP Logged Link to Post Post Reply Quote ttimms20
Hello everyone, back again. I'm installing a Viper 5906, dball2, and a CHTHD1 t harness. The t harness is suppose to take away a lot of time from the install but I'm not sure what all will need to be connected.
So far I have all the powers and grounds, the horn, auxs, gwr, ignition in/out, and hood switch.
Any suggestions, I'm still researching.
We Ride
Platinum - Posts: 7,827
Posted: May 26, 2016 at 6:23 AM / IP Logged Link to Post Post Reply Quote kreg357
First, here is a link to a Pictorial on that truck :
https://www.the12volt.com/installbay/forum_posts.asp?tid=140728
The Pictorial uses different components and is a R/S with Keyless Entry only, no alarm functions, but shows how
easy that truck is to do ( without the extra expense of a T-Harness).
Next, I don't use DB-ALL2's but a review of the install guide leads me to believe that if you use the CHTHD1
T-Harness, you must also go with D2D mode. You should be following the Type 1a diagram on Page 3 if you have the
Revision 7 harness. You should not be using a T-Harness and making the W2W Type 1c connections shown on Page 5.
The only necessary hardwire connections are :
Viper +12V to RAM 1500 +12V ( shown in Pictorial )
Viper Chassis Ground to RAM 1500 Chassis Ground.
Viper Hood Pin input to kit supplied and installed Viper Hood Pin switch.
Viper Pink (+) Ignition Output to DB-ALL2 Pink wire on T-Harness
DB-ALL2 Violet/Green and Violet/Brown to RAM 1500 Parking Light MUX wire ( shown in Pictorial ).
DB0ALL2 Yellow/Black RAP wire to RAM 1500 Door Pin ( shown in Pictorial ).
Plus the T-Harness to the DB-ALL2 and the RAM 1500 ignition node harness.
That's it. No need for the dashed Blue Tach wire as it's handled by the D2D harness just like all the other
supported functions shown on Page 2 of the DB-ALL2 Install Guide. Think I read a post where a professional
installer claimed to see his supervisor do one of these trucks in 12 minutes flat.
ttimms20
Member - Posts: 43
Posted: May 28, 2016 at 2:24 AM / IP Logged Link to Post Post Reply Quote ttimms20
Thanks for that, what I'm running into is do I connect all 4 12v wires or a certain one.
We Ride
Posted: May 28, 2016 at 3:24 PM / IP Logged Link to Post Post Reply Quote kreg357
I believe that with your installation you only need to connect the two solid Red wires to +12V constant. The other two wires ( RED / Whtie and RED / Black ) can be left un-connected.
ttimms20
Member - Posts: 43
Posted: May 29, 2016 at 3:10 PM / IP Logged Link to Post Post Reply Quote ttimms20
All steps followed, but can't access the control center. Remote works for aux, aux/trunk, and panic. No locking/arming and remote start keep saying toggle off but it's connected and in the on position.
We Ride
ttimms20
Member - Posts: 43
Posted: May 29, 2016 at 3:11 PM / IP Logged Link to Post Post Reply Quote ttimms20
Bitwriter is reading box
We Ride
Wednesday, July 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
