weird compustar?
tekin
Member - Posts: 45
Posted: July 17, 2016 at 1:01 AM / IP Logged Link to Post Post Reply Quote tekin
ok I have a compustar cm7000AS brain
I installed it about a year ago, and now have a little issue
the whole think works but the trunk release stopped working, so I am curious how I can test this.
I am using a trunk popper not a factory one.
If I hold button 3 on the remote it use to unlock the doors and pop the trunk but now it just unarms and unlocks the doors.
I can not remember if I put a relay but the wire I used is the violet/white, I used a volt meter and put he positive lead at the wire and negative to the chasis and there is no output on the wire. I can not remember if I put a relay, can anyone help me out it is a 67 Camaro, and I don't wanna take the whole dash, cluster out as the brain is buried
tekin
Member - Posts: 45
Posted: July 17, 2016 at 1:45 PM / IP Logged Link to Post Post Reply Quote tekin
can anyone help me at all, also just to refresh my memory would I require a relay, and or hook straight to the popper
tekin
Member - Posts: 45
Posted: July 18, 2016 at 12:32 PM / IP Logged Link to Post Post Reply Quote tekin
still no one
lurch228
Silver - Posts: 1,338
Posted: July 18, 2016 at 2:30 PM / IP Logged Link to Post Post Reply Quote lurch228
You should use a relay as (-250ma_ is for trigger loads to operate a relay.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
