Viper 4105V w/ Fortin INT-SL-PL 02 Trailblazer
shawnchristy
Member - Posts: 7
Posted: September 22, 2016 at 5:02 PM / IP Logged Link to Post Post Reply Quote shawnchristy
Hey folks, I have been on this site (and all over the internet) for days trying to find what I'm looking for, and I either am just not seeing it, or it really isn't here. If it is here, my apologies. Please send me in the right direction. I did see a picture of an install of the Viper 4105V, but it had a different bypass module, and I'm lost.
I have an 02 Chevy Trailblazer (newer body style) that I'm trying to install the Viper 4105V along with the Fortin INT-SL-PL in. Does anyone know where I can find the wire to wire instructions? For example, I saw one post where it said I needed to access two of the wires on my OBD port, but no explanation of why, or what wires of what component to hook them to. (bypass module, or remote start) The wiring diagrams I found for both doesn't mention the OBD port either.
To be clear, I need the full diagram, not just the OBD wires. I'm not getting fancy with windows or anything. I just want the car to remote start and that's it. I didn't want to have to ask you guys for help, but I've exhausted every avenue I could find before posting this. (5 days in so far!)
Any help would be MUCH appreciated! Thank you in advance!
beegbie
Copper - Posts: 341
Posted: September 22, 2016 at 6:47 PM / IP Logged Link to Post Post Reply Quote beegbie
Fortin lists a can-sl-pl and an int-sl on their site. No int-sl-pl. Are you sure this is what you have?
lurch228
Silver - Posts: 1,338
Posted: September 22, 2016 at 7:25 PM / IP Logged Link to Post Post Reply Quote lurch228
Directwire
2002 Chevrolet TrailBlazer - North America
Remote Start, Security, Keyless Entry, Accessories
Item / Wire Color / Polarity / Wire Location
12 Volts red (40A) + ignition harness
Second 12 Volts RED / white (40A) + ignition harness
Starter yellow + ignition harness
Ignition pink + ignition harness
Second Ignition white + ignition harness
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness or BCM, tan plug, pin E3
Data Bus yellow (resistor code), org/blk to black (ground) Passlock 2 Passlock sensor on ignition key cylinder
CAN Bus SW purple (J1850 Class 2 Serial Data) data data link connector, black 16 pin plug, pin 2
Power Lock use Directed interface module or see Tech Doc 1053
Power Unlock see power lock
Lock Motor gray 5 wire fuse box under left rear seat
Driver Unlock Motor tan 5 wire driver door module in door
Passenger Unlock Motor tan 5 wire fuse box under left rear seat
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green (driver door key cylinder) - driver door module in door
Disarm No Unlock see factory alarm disarm
Parking Lights (+) brown + fuse box under left rear seat
Parking Lights (-) gray/black - headlight switch or BCM, tan plug, pin E5
Hazards white - hazard switch
Turn Signal (Left) dk. green + turn signal switch
Turn Signal (Right) lt. green + turn signal switch
Headlight white - headlight switch or BCM, tan plug, pin F9
Reverse Light lt. green + fuse box under left rear seat
Left Front Door Trigger gray/black - driver door module in door
Right Front Door Trigger BLACK/ white - passenger door module in door
Left Rear Door Trigger lt. blue/black - fuse box under left rear seat
Right Rear Door Trigger lt. GREEN/ black - fuse box under left rear seat
Dome Light gray/black + fuse box under left rear seat
Trunk/Hatch Pin pink/black - liftgate module in liftgate
Rear Glass Pin purple - liftgate module in liftgate
Hood Pin pink/black (export only) - hood switch or BCM, tan plug, pin E6
Trunk Release Motor tan (liftgate unlock motor) 5 wire liftgate module in liftgate
Tachometer white ac instrument cluster or PCM, blue plug, pin 49
Fuel Pump gray + underhood fuse box, 32 pin plug, pin F3
Rear Defroster purple 5 wire liftgate module in liftgate
Mirror Defroster (Class 2 Serial Data)
Speed Sense dk. GREEN / WHITE ac instrument cluster or PCM, blue plug, pin 32
Brake Wire white + brake switch or fuse box under left rear seat
Parking Brake lt. blue - parking brake switch or fuse box under left rear seat
Horn Trigger BLACK / YELLOW to black - horn switch or BCM, tan plug, pin E12
Wipers pink (L), dk. blue (H) +,- wiper switch
Left Front Window (Up/Down) dk. blue - brown A driver door module in door
Right Front Window (Up/Down) lt. blue - tan A passenger door module in door
Left Rear Window (Up/Down) dk. blue - brown A left rear window switch in door
Right Rear Window (Up/Down) dk. blue - brown A right rear window switch in door
Sun Roof (Open/Close) brown - orange (function with ignition on only) - sunroof switch
Memory Seat 1 white + driver door module in door
Memory Seat 2 purple + driver door module in door
Audio
Item Wire Color Polarity Wire Location
Radio 12V orange + radio harness
Radio Ground BLACK/ white - radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination BROWN / white + radio harness
Power Antenna gray + radio harness
Left Front Speaker (+/-) tan - gray +,- radio harness or amplifier in right rear quarter panel
Right Front Speaker (+/-) lt. green - dk. green +,- radio harness or amplifier in right rear quarter panel
Left Rear Speaker (+/-) brown - yellow +,- radio harness or amplifier in right rear quarter panel
Right Rear Speaker (+/-) dk. blue - lt. blue +,- radio harness or amplifier in right rear quarter panel
Notes:
Second Accessory: Must be powered up. If not, the vehicle will crank as soon as it sees ignition.
Keysense: The BCM is attached to the fuse box under the left rear seat.
Parking Lights (-): The BCM is attached to the fuse box under the left rear seat.
Headlight: The BCM is attached to the fuse box under the left rear seat.
Hood Pin: The BCM is attached to the fuse box under the left rear seat.
Tachometer: The PCM is attached to the driver side of the engine.
Speed Sense: The PCM is attached to the driver side of the engine.
Horn Trigger: The BCM is attached to the fuse box under the left rear seat.
shawnchristy
Member - Posts: 7
Posted: September 22, 2016 at 7:27 PM / IP Logged Link to Post Post Reply Quote shawnchristy
shawnchristy
Member - Posts: 7
Posted: September 22, 2016 at 7:32 PM / IP Logged Link to Post Post Reply Quote shawnchristy
Yes sir. I copied it straight from the box. It's a white sticker that says "INT-SL-PL". The sku is 7 70350 00228 2" if that helps.
Thanks for your help!
lurch228
Posted: September 22, 2016 at 7:46 PM / IP Logged Link to Post Post Reply Quote lurch228
Here is the wiring with labeled Pictures in PDF.
2002 Trailblazer wiring with Labeled wire location Pictures
beegbie
Copper - Posts: 341
Posted: September 22, 2016 at 7:48 PM / IP Logged Link to Post Post Reply Quote beegbie
Take a look at the guide and see if it your module looks like this.
Int-sl:    http://fortin.ca/download/40441/int_chevrolettrailblazer_0207.pdf
shawnchristy
Member - Posts: 7
Posted: September 23, 2016 at 1:36 PM / IP Logged Link to Post Post Reply Quote shawnchristy
beegbie,
I just downloaded that pdf, and it is not the same as I have. The box mine came in says "INT-SL-PL", but the installation guide it came with says "INT-SL+". It has a "vehicle fit guide" that says what features you can hook to it, and what cars it will work on. I purchased it on Amazon with my remote start.
I am not good with this site yet, as far as how to upload pics or anything. I see other people have done it, but I can't see how they do it. If you want to drop your email address to me, I'd be happy to send you a pic of it.
As far as the wiring goes, I'm getting ready to dig into it now. I'll post something when I get done and let you guys know how it turned out.
Thanks a million for the help you guys have given so far!! I very much appreciate you guys!!
lurch228
Posted: September 23, 2016 at 3:40 PM / IP Logged Link to Post Post Reply Quote lurch228
The Model of Fortin you have is aINT-SL(Self Learning)-PL(PassLock)
And the firmware has been upgraded to the INT-SP+ which uses the same hardware loaded with different firmware. That combines the Transponder and passlock all into one firmware for more Brands of vehicles.
Fortin INT-SL-PL Guide REV. J (Most current from fortin)
If any Functions listed in this current Guide are not listed in the Original that came with yours. You would need to update the firmware to enable them.
shawnchristy
Member - Posts: 7
Posted: September 23, 2016 at 4:14 PM / IP Logged Link to Post Post Reply Quote shawnchristy
lurch228,
Yes, that is what I have! If you wouldn't mind clarifying a couple of things for me, I would greatly appreciate it. I'm installing the units now.
1) For the "Power Unlock" and "Power Unlock" from the diagrams you gave, it says "use Directed interface module or see Tech Doc 1053". Does this mean to use a relay? I looked online, and even found an old post on this site, but when I clicked the links, it said the page couldn't be found.
2) What wires from the Fortin bypass am I using, and where do they go? I'm presuming I am doing the "Data Link" option on the instruction sheet?
Once again, I appreciate all the help!
