Viper 4806v and ALCA
mhunguyen
Member - Posts: 32
Posted: October 11, 2016 at 8:26 PM / IP Logged Link to Post Post Reply Quote mhunguyen
I am planning to put a 4806v on a 2014 Toyota Rav4 using Idatalink ALCA, just have a few questions hoping to get some help.
Based on the Idatalink guide for firmware ADS-AL(DL)-TL6-EN, it's saying WARNING: DO NOT CONNECT ANY OTHER ACCESSORY,IGNITION OR START WIRE FROM THE REMOTE STARTER TO THE VEHICLE. THE INTERFACE MODULE IS HANDLING THE REQUIRED VEHICLE POWER AND START SEQUENCE FROM THE PUSH TO START BUTTON CIRCUIT. This is pretty straight forward, but is it saying not to connect the following 12volt wires as well on the 8-Pin Harness?
RED / BLACK (+) 12VDC CONSTANT INPUT for ACC and starter relays
RED (+) 12VDC CONSTANT INPUT for ignition 1 relay
Also on the 6 Pin connector is this the parking light output wire?
WHITE - PIN 30 of LIGHT FLASH RELAY
thanks
lurch228
Silver - Posts: 1,338
Posted: October 12, 2016 at 2:49 AM / IP Logged Link to Post Post Reply Quote lurch228
The 4806 has separate main power and ground so they are not needed to power the onboard remote start relays.
Yes it is the light output for the parking lights.
mhunguyen
Member - Posts: 32
Posted: October 13, 2016 at 2:45 PM / IP Logged Link to Post Post Reply Quote mhunguyen
THank you Lurch... is this the same case if i were to use the 5806 instead of the 4806?
lurch228
Posted: October 13, 2016 at 3:45 PM / IP Logged Link to Post Post Reply Quote lurch228
Yes same with any R/S capable unit or brand.
