1997 Subaru Legacy Avital 4103 Wont Crank Engine
boxerlove
Posted: November 01, 2016 at 12:40 PM / IP Logged Link to Post Post Reply Quote boxerlove
Hello,
Decided to tackle my first remote start install. I am experienced with wiring and reading diagrams but im stumped this time.
Followed my cars wiring diagrams found online and matched up the Acc,Ign,Starter,and 12V Constant wires in the Ignition harness. Properly soldered the connections on. Grounded the Neutral Safety Switch wire, and grounded the main harness ground,Hooked up the Door locks and they work as they should but when i hit the remote start button on the remote the cars dash lights up like i turned the key, Fuel pump primes, and then nothing. The car does not crank. Im a bit confused at what i may have missed? I know its close and has to be something minor. Any and all info is appreciated. Thanks!
boxerlove
Posted: November 01, 2016 at 12:44 PM / IP Logged Link to Post Post Reply Quote boxerlove
Ive also switched in the Avital menu's to not use the "virtual tach" option . I switched it to Voltage mode thinking that may be it but no luck.
Below i have highlighted the wires i have hooked up to their corresponding wires in the car.
1997 Subaru Legacy Avital 4103 Wont Crank Engine -- posted image.
smokeman1
Platinum - Posts: 1,589
Posted: November 01, 2016 at 1:02 PM / IP Logged Link to Post Post Reply Quote smokeman1
You need to connect the other RED H2/6 wire to 12 volts constant
boxerlove
Posted: November 01, 2016 at 1:04 PM / IP Logged Link to Post Post Reply Quote boxerlove
Was just thinking of trying that. Will report back, Hopefully with a starting car ;)! Im going to feel real dumb when it works lol.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
