keyless entry problems cont.
hammj99
Posted: May 30, 2003 at 10:38 AM / IP Logged
I thank you all for the help that you gave me but i still am having problems. My alarm is a delta pro 5005 and my truck is a 94 chevy silverado.  I just got a DLS and installed it but on the main harness of the alarm there is a blue/white wire that is to conect to the (-)passenger door lock.  The DLS didn't come with a place to connect this wire. Do I need to tie it into the passenger door lock wire or can it be tied into the blue lock wire on the 3-wire plug for the alarm.  If this doesn't work i am sending it back to delta because i think the k/e system is shot. thanks for any help.
draasch
Gold - Posts: 2,172
Posted: May 31, 2003 at 2:37 PM / IP Logged
did you wire it up as a :Reversal Rest At Ground Door Lock Diagram.
on your dls you should have 3 small wires going to a red plug....
the red goes to 12v fused. the grren is for lock and the blue is for unlock.
the large purple wire also needs to go to 12v fused. 10 should be good.
the output from the alarm needs to be a neg out.you should have two of them one for lock and the other for unlock. you may not be able to use the red plug on the DLS. you just cut it off wire it up without it..
i dont know that brand of unit, but you should be able to wire up the DLS.
if you need and diagram, send me you e-mail and i will shoot one to u.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
