Stumped xk09 Bypass and Battery Reset
cryptic
Posted: January 09, 2017 at 9:26 PM / IP Logged Link to Post Post Reply Quote cryptic
I recently installed Avital 4103LX in a 2004 Jeep Grand Cherokee. For the bypass, I used an Xpresskit xk09 with newest flash 9.JDL v2.06. Everything is installed and works correctly.
Doors function, tach programmed. Headlights flashed twice when learning tach which indicates the signal came from D2D. The bypass learned successfully the key. The Jeep remote starts fine.
So, The issue I have: The Jeep is stored for long periods. It has a battery disconnect attached to the negative terminal of the battery.After disconnecting the negative terminal, once I try to remote start the Jeep it nearly instantly dies. The immobilizer icon(Key in a circle with line) shows up on the dash and the Jeep turns off. If I reset the the xk09 by unplugging it and holding down the program button. It relearns the key and will remote start again.
Is this normal? Is my xk09 defective? Is something wired up wrong to cause the xk09 to malfunction?
XK09 D2D to 4103
10 Black to Chasis
13: Violet/Brown - to PIN 11 Yellow Head Lights
15: Yellow: Immobilizer Module PIN 3 Car Side
Cut Wire
17: Orange: Immobilizer Module PIN 3 Transponder Side
18: Green: PIN 2 OBDII
4103
H1/6 -- Horn
H1/8 -- GROUND
1 PINK --   Dark Blue @ Ignition switch harness
2 PURPLE -- Yellow @ Ignition switch harness
3 ORANGE -- ACCESSORY CIRCUIT       RED / Black @ Ignition switch harness
4 RED --   Red @ Ignition switch harness
5 PINK/WHITE (+) PROGRAMMED to ACCESSORY BLACK/ Orange @ Ignition switch harness
6 RED --        Pink/Black @ Ignition switch harness
H2/1 -- Ground
H2/4 -- HOOD PINSWITCH
TL:DR -- Remote Start doesn't work after battery reset. I blame the bypass but it could be something else.
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
