2017 Hyundai Tucson lock motor wire
sbarr
Member - Posts: 8
Posted: February 02, 2017 at 9:04 AM / IP Logged Link to Post Post Reply Quote sbarr
I would like to utilize the lock motor wire for my remote start activation signal. It is a 2017 Hyundai Tucson, push to start. All I can find is I'm looking for an orange wire. Is anyone familiar with this wire and/or its location? Thank you.
chev104275
Gold - Posts: 1,436
Posted: February 02, 2017 at 1:55 PM / IP Logged Link to Post Post Reply Quote chev104275
This for a 16 I'm not sure if it's the same
LOCK MOTOR WIRE     ORANGE (5-Wire Type)     @ DASH FUSE BOX, (WHITE, 20-PIN PLUG(E), PIN 9
sbarr
Member - Posts: 8
Posted: February 02, 2017 at 9:04 PM / IP Logged Link to Post Post Reply Quote sbarr
Thank you for your reply.   My remote starter requires a (-) pulse, programmable from 1 to 4 pulses. If I'm looking at the vehicles system correctly the lock motor orange wire (5 wire) is more complex than I need. I simply need a (-) pulse for each press of the Lock button on the factory remote. Unfortunately I did not realize I could've programmed the module when using the data setup to receive a three pulse lock signal for remote start. The module came pre-programmed from the supplier, it's probably not worth sending it back to have it reprogrammed.
Thank you, sbarr
chev104275
Gold - Posts: 1,436
Posted: February 03, 2017 at 5:53 AM / IP Logged Link to Post Post Reply Quote chev104275
You can use a relay to invert the polarity from (+) to (-). Look in the relay section here.
Friday, October 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
