DEI 530T window issues, 01 Silverado
Slammed01
Copper - Posts: 89
Posted: February 25, 2017 at 9:40 AM / IP Logged Link to Post Post Reply Quote Slammed01
Hey all-
Today my passenger side window wouldn't roll down on my 01 silverado, switch clicks but no movement. Ever since I had the dei 530 window modules installed the window sticks and goes slow. Alreaafy been back to the shop 1 time for same issue (years ago as I barely drive it). They lubed tracks and hooked up a cable to battery for more power. Still went slow and stuck, just delt with it.
Not sure if a fuse on 530 could cause window function to stop or if regulator/motor. Is install for these 530s cut wire and hardwire straight to window motors? Worse case sounds like soldering a 3-4 stock wires per side?
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
