Viper 4105v w/ dball2
garret607
Member - Posts: 6
Posted: March 01, 2017 at 10:12 PM / IP Logged Link to Post Post Reply Quote garret607
so i wired in the viper 4105v and the dball2 after having the place i bought the dball2 from flash it for me. im roughing everything in so it is accessible, i got as far as the remote start working and i moved my entire alarm and byspass setup and now its as if there is no power. i have checked cab fuses, hood fuses, and alarm fuses. i have 12v to the alarm but no LED, no horn beeps, no nothing. its as if its dead. not responsive to valet switch either. im ripping my hair out with this one.
silvercivicsir
Copper - Posts: 416
Posted: March 02, 2017 at 11:19 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
how is your ground? did you power up all the 12v wires? there are 4 of them in total, 3 thick and 1 thinner one
garret607
Member - Posts: 6
Posted: March 02, 2017 at 2:54 PM / IP Logged Link to Post Post Reply Quote garret607
Grounds are solid, alarm module ground, dball2 ground and nuetral saftey switch all grounded togther at chassis ground. Less then 1 ohm continuity.
garret607
Member - Posts: 6
Posted: March 02, 2017 at 2:59 PM / IP Logged Link to Post Post Reply Quote garret607
All power wires have battery voltage at alarm connector. So no issues there either.
I think I figured it out, I accidentally touched the orange wire, 500ma ground while locked/anti grind to chassis ground and I think I fried the alarm module, because everything was working before that and now no led, and no reponse from the alarm module.
silvercivicsir
Copper - Posts: 416
Posted: March 02, 2017 at 4:45 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
shorting a "output" wire to ground (the chassis), won't do anything.. giving it 12v is a different story.. try unplugging the unit, and plugging it back in.. (maybe it locked up... common on the autostarts brand. does the Viper brain smell burnt? Also try relearning the remotes.
garret607
Member - Posts: 6
Posted: March 02, 2017 at 5:18 PM / IP Logged Link to Post Post Reply Quote garret607
i did try unplugging it for around 30 mins and plugging it back in with no change. still no LED, not responsive to Valet switch at all. I disassembled the unit and checked the circuit board for any sign of burn marks or burnt smell. did not see anything abnormal, it did have a slight smell to it, very faint, almost like a burnt smell but hard to put my finger on it. the truck still starts fine with the normal key and have no problems with normal operation.
garret607
Member - Posts: 6
Posted: March 03, 2017 at 11:10 PM / IP Logged Link to Post Post Reply Quote garret607
so i ordered a 2nd alarm module, roughly installed it and it worked. disconnected it, routed all the wiring for finish in and plugged everything in and nothing, same as last one. i dont know what the hell is happening.
garret607
Member - Posts: 6
Posted: March 04, 2017 at 11:45 PM / IP Logged Link to Post Post Reply Quote garret607
cool. awesome. I will try that, thanks for all the help. *insert sarcasm*
thanks silvercivicsir for the reply and taking a crack at it.
