Ram 2017 Horn Wiring
hudi
Member - Posts: 11
Posted: July 07, 2017 at 2:36 PM / IP Logged Link to Post Post Reply Quote hudi
Does anyone know the wire color and harness that the horn trigger from the dash is?
I need to hook up an external horn
thanks
Immediate replies are appreciated
Scorpion
wirewise
Moderator - Posts: 489
Posted: July 07, 2017 at 2:41 PM / IP Logged Link to Post Post Reply Quote wirewise
This is for 2013 through 2016, not sure if 2017 is the same, but worth checking.
HORN      DARK GREEN/WHITE (+)      @ BCM, BLACK 24-PIN PLUG, PIN 23
~wirewise~
hudi
Member - Posts: 11
Posted: July 07, 2017 at 2:43 PM / IP Logged Link to Post Post Reply Quote hudi
I read that first, but there is no Dark green/white wire
There is a light green/white wire. I tested that first but its not it
Scorpion
wirewise
Posted: July 07, 2017 at 2:45 PM / IP Logged Link to Post Post Reply Quote wirewise
Why not just test at the horn and go from there?
~wirewise~
hudi
Member - Posts: 11
Posted: July 07, 2017 at 2:48 PM / IP Logged Link to Post Post Reply Quote hudi
In this truck its buried in the driver side front panel. Too much work to get to it.
I also figured id get at it through the Relay, but if there is a relay, its not in the Fuse box where all the other relays are.
Any other suggestions?
Scorpion
wirewise
Posted: July 07, 2017 at 2:53 PM / IP Logged Link to Post Post Reply Quote wirewise
I'd test the harnesses coming off the column with a DMM. Lead will likely show 12V+ at rest and continuity to ground when horn button is pressed.
~wirewise~
Platinum - Posts: 13,726
Posted: July 07, 2017 at 3:35 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Ram 2017 Horn Wiring -- posted image.
