Wiring hack to auto fold mirrors with RKE 2010 C
finallyac-1500
Posted: February 02, 2018 at 1:31 PM / IP Logged Link to Post Post Reply Quote finallyac-1500
After searching the forums, I found only one post that was similar to my question, here: https://www.the12volt.com/installbay/forum_posts.asp?tid=136352
My mirrors, locks and auto start are all factory. Later models you simply program the fold to the lock in the DIC. No such option in the 2010 model. It looks like it should be simple to wire in. Wish I was smarter! Thanks
Bill
I still have so much to learn.
geepherder
Platinum - Posts: 3,668
Posted: February 02, 2018 at 5:31 PM / IP Logged Link to Post Post Reply Quote geepherder
What is the year, make and model of the vehicle?
finallyac-1500
Posted: February 03, 2018 at 12:42 AM / IP Logged Link to Post Post Reply Quote finallyac-1500
2010 Chevy C-1500 LTZ. Sorry I omitted that info!
geepherder
Posted: February 03, 2018 at 6:17 AM / IP Logged Link to Post Post Reply Quote geepherder
I'm assuming there's a button used to fold the mirrors. Do you have to press/hold, or just press/release? If it's just a momentary press, maybe you can simulate a button press using a relay controlled with the ignition. This probably requires disassembly of the switch and soldering some small wires inside. If you go this route, I'd buy a spare switch before attempting.
Alternatively, you could go directly to the motor wires, and use a window module, or something similar. It looks like the yellow and light blue wires are what you need: http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=176393
Posted: February 03, 2018 at 10:06 AM / IP Logged Link to Post Post Reply Quote howie ll
That's the safest.
Here's another:-
And another!:-
