DEI 529t, Clifford Matrix RS2.1, 95 Bronco
kurdtch
Posted: May 16, 2018 at 11:47 AM / IP Logged Link to Post Post Reply Quote kurdtch
Hi folks, new user, wish I had found this site a lot sooner.
My question is, I have a Clifford Matrix RS2.1 w/remote start in my 1995 Bronco. I just purchased a DEI 529t module so I can use it for my rear tailgate window (the key switch is not working). I have the manual for both alarm and 529, but I'm not sure which lead on the alarm is the one to use with the module (the lead that will work with the remote to trigger the module). Any help is appreciated. Thanks.
Chris Kurdt
geepherder
Platinum - Posts: 3,668
Posted: May 17, 2018 at 4:10 PM / IP Logged Link to Post Post Reply Quote geepherder
I suggest connecting the green/white factory alarm rearm wire so the window will roll up automatically when you arm the system.
If you also want to be able to roll down the window remotely, you can connect the red/white validity output for that.
kurdtch
Posted: May 18, 2018 at 5:43 PM / IP Logged Link to Post Post Reply Quote kurdtch
Thanks! I 'Think' I figured it out. I managed to find a video of someone installing this for four window rollup, it looks like I can splice the two sets (orange and orange/black) into the orange in my system (I want to roll the window up and down using the remote, not when I arm it, because the switch is non-functional). I then need to take both sets of leads (two wires for one window rollup and the other set for other rollup, and use the second as the roll down). Then I can use the programmed buttons to roll it down when I need to then roll back up. I'll give it a shot and let you know how it comes out.
Chris Kurdt
