2014 Toyota Corolla, ADS-BLADE-AL, CM7000
otterslide
Member - Posts: 26
Posted: August 11, 2018 at 5:43 PM / IP Logged Link to Post Post Reply Quote otterslide
I'm trying to figure out the wiring on this CM7000 module, if anyone can help it would be appreciated. I have the TL9 firmware already flashed.
All I need is to know which wires I have to hook up, besides the ones in the Type 4 diagram.
For example, Red/White is not in the type4 diagram, so I don't need to hook up red/white?
Same as Green/White which is parking lights, and white which is ACC. The car does have a ACC and a second 12V(lt.green). I was going to hook up CN1 Red to Car Blue(7.5A - As in Type4 Diagram) and Red/White to lt.green(5A) , but the Red/White is not mentioned at all.
There are two parking light wires also, one on the CN1 harness(12V+) and one on the CN5, -250mA LIGHT OUT, and the car has a green(+) and white(-) parking wires, so I'm not sure which one to go with? Probably the Green/White on the CN1 Green/White, to car Green at dash fuse box, white 40pin plug 3E, pin 29. ?
Anything else I need to connect that I may be missing? I have so far: CANH CANL SIL RDA on the Blade hardness and 12V(red) Start(yel), IGN(Grn), 2nd Ignition(blu) on the CN1 figured out.
Any help is appreciated!
otterslide
Member - Posts: 26
Posted: August 13, 2018 at 3:26 PM / IP Logged Link to Post Post Reply Quote otterslide
Ok I figured it out, the wiring diagram is for the Low Current harness, so the HC harness is not even used with the red/white wire.
I still don't know which other wires are necessary, like the green parking lights wire probably is.. and I found another wire somebody is hooking up in a video which I'm not sure what is for yet, probably the horn.
otterslide
Member - Posts: 26
Posted: September 01, 2018 at 10:33 PM / IP Logged Link to Post Post Reply Quote otterslide
Lights, auto-light cut relay, horn and hood pin are the other wires needed. Everything else is taken care of by the blade. It's unfortunate Compustar doesn't have a built-in autolight cut relay like others do.
Looks like no OEM hood status on 2014 Corolla unfortunately.. maybe only ones with alarm system have it.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
