Finding TXCT and Code Plug, 2010 Toyota Corolla
vaxildan
Posted: August 21, 2019 at 1:23 PM / IP Logged Link to Post Post Reply Quote vaxildan
Im trying to find the plug for the txct and code wires to finish wiring the bypass for a compustar alarm
Donovan Reeves
iskidoo
Silver - Posts: 1,046
Posted: August 21, 2019 at 4:01 PM / IP Logged Link to Post Post Reply Quote iskidoo
Should be plugged into the key cylinder. Take the steering wheel shroud apart if you can’t find the wires lower in the dash.
Steve G
silvercivicsir
Copper - Posts: 416
Posted: August 23, 2019 at 4:06 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
is it a G key? This year corrolla sucks, as the imo/im is in the engine compartment. If you are using an Idata AlCa, try flashing it for TL-5 first and see if it program, it does it will work, if not, you will need to use TL-4 and get the wires from engine bay.
vaxildan
Posted: August 23, 2019 at 4:11 PM / IP Logged Link to Post Post Reply Quote vaxildan
The key is a standard 40bit with the dot, not G or H. I ended up finding the right wires by unplugging the plugs where the diagram showed them and seeing which one wouldn't allow the car to start
Donovan Reeves
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
