Parking Lights Not Flashing, Viper 3105v, 2002 Toyota Tacoma
terrythetaco02
Posted: January 18, 2020 at 9:19 PM / IP Logged Link to Post Post Reply Quote terrythetaco02
I am new to all this alarm system stuff and recently installed a viper 3105v alarm system on my 2002 tacoma and everything works except the parking lights wont flash. I wired the white parking light wire from the brain of the system to the (-) parking light wire on the wiring harness on the front of the fuse box. The first time i checked and the fuse in the white parking light wire was blown so if anyone can tell me how to fix this i would appreciate it, thanks.
cpalmer
Copper - Posts: 115
Posted: January 18, 2020 at 10:09 PM / IP Logged Link to Post Post Reply Quote cpalmer
Check that you have the 3105v set to negative output.
terrythetaco02
Posted: January 18, 2020 at 10:23 PM / IP Logged Link to Post Post Reply Quote terrythetaco02
This might sound like a stupid question but im only 15 and this is the first time ive done anything like this so how do you make sure its set to negative
geepherder
Platinum - Posts: 3,668
Posted: January 19, 2020 at 6:59 AM / IP Logged Link to Post Post Reply Quote geepherder
15 is a great time to start in this field.
Look here:
https://pdf.crutchfieldonline.com/ImageBank/v20130828111200/Manuals/607/6073105V_DL.PDF
On the left, select "Quick Reference Install Guide".
On the same side as the main wiring harness, you'll notice a jumper. It can be placed in one of two positions. Make sure it's in the position marked with a minus sign (-) in the picture (the position closer to the main harness).
terrythetaco02
Posted: January 19, 2020 at 8:41 AM / IP Logged Link to Post Post Reply Quote terrythetaco02
Thanks i just got done fixing it and the parking lights flash now when i arm/disarm my truck
