Driver Priority Unlock
likesbigtrucks
Posted: May 19, 2020 at 10:45 PM / IP Logged Link to Post Post Reply Quote likesbigtrucks
So I want to set my alarm up so that my drivers door unlocks on first press then the rest on the second.
Is this something that can be reasonably done using relays or do I need to find an alarm with this feature?
geepherder
Platinum - Posts: 3,668
Posted: May 20, 2020 at 2:23 AM / IP Logged Link to Post Post Reply Quote geepherder
Since we don't know your vehicle/alarm this response is in generalities. There are different variables involved. Many vehicles work this way from the factory and there is no extra work involved.
Otherwise, if your alarm has an option for a 2nd unlock output, the unlock output will control a relay and drive just the driver's door actuator (this usually involves cutting one factory wire). The 2nd output will go to the vehicle's unlock wire.
Sunday, January 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
