If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, March 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
With the image from above (hopefully you can see), I've got the white wire (closing signal) connected to the G-R wire in the car for LOCK. I got the white/black wire connected to R-W for UNLOCK. I then took yellow & yellow/black and connect them both to the ground. Is this the correct way of doing it by taking them to the ground? or am I supposed to tap those into something else?
thank you for the assistance!
