Viper 5806v Alarm Settings
itolond
Copper - Posts: 87
Posted: March 20, 2021 at 7:28 PM / IP Logged Link to Post Post Reply Quote itolond
Hi Forum,
I have the5806v installed and so far all good. The rear cab door is now auto close central lock arm. It takes about 10 secs max to fully close.
How do I place a delay on arm to allow for this ( otherwise I get the door error on remote all the time)
cpalmer
Copper - Posts: 115
Posted: March 22, 2021 at 12:46 AM / IP Logged Link to Post Post Reply Quote cpalmer
Should be a setting to turn off door error chirp.
mgoetz74
Silver - Posts: 424
Posted: March 22, 2021 at 9:44 AM / IP Logged Link to Post Post Reply Quote mgoetz74
menu 2-4
The System Features Learn Routine dictates how the unit operates. It is possible to access and change most of the feature settings using the Control Center button.
1. Open a door.
2. Turn the ignition on, then OFF.
3. Select a Menu. Press and hold the Control Center button. The number of siren chirps indicates the Menu number. 1 LED flash and honk indicates Menu 1, 2 LED flashes and honks - Menu 2 and 3 LED flashes and honks for Menu 3.
4. When the desired Menu chirps are heard, release the Control Center button.
5. Select a Feature. Press and release the Control Center button the number of times corresponding to the feature you wish to change. Then press and hold one more time to select the features. Do NOT release the Control Center button.
6. Program the Feature. While holding the Control Center button, you can program the feature using the remote control.
7. The Control Center LED will flash and the siren will chirp the number of times equal to the option. For features with only two options; = option 1, while = option 2. For features with more than two options; selects the options in ascending order, while selects them in descending order.
