Passlock 2 or not passlock 2?
skyace4
Member - Posts: 18
Posted: June 09, 2003 at 11:34 PM / IP Logged
On the Chevy 2003 S-10 V-6 Vortec does the pickup truck have a passlock 2 system and if it does what are the colors of the wires to use under the steering wheel for a pass-mod unit.
I am installing a Commando RS-560 with a remote start feature and need to get the correct wires identified on the S-10.
ThanksPasslock 2 or not passlock 2? -- posted image.
nighthawk2k
Copper - Posts: 116
Posted: June 10, 2003 at 12:07 PM / IP Logged
First thing to check is to see if the key says PK3 on it if it does then you need a 555u transponder bypass if not it's passlock. If it is passlock there should be 2 yellow wires. one is the passlock wire that you need to use.
Tommy
-Clifford/Directed/Alpine-Audio & Security-
New York InstallerPasslock 2 or not passlock 2? -- posted image.
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
