2006 Ford E-450 Motorhome, Viper 211HV, Door Locks
hsfort
Posted: September 01, 2023 at 9:05 AM / IP Logged Link to Post Post Reply Quote hsfort
I am attempting to wire up a Viper 211HV alarm in a 2006 Ford E450 Motorhome (2 Door). Do I need to install 2 extra 5 pin relays to make the lock/unlock feature work correctly as shown in the relay section of this link as a 5 wire alternating 12 volt positive Type C relays? Additionally are the violet/black (H1/7) and violet (H1/9) lock/unlock input wires on the Viper brain connected to 12 volts for this application? Will this configuration supply a ground pulse on green/black (H1/5) lock and blue/black (H1/8) unlock to energize the external relay coils to lock and unlock the doors?
hf
hsfort
Posted: September 03, 2023 at 8:00 AM / IP Logged Link to Post Post Reply Quote hsfort
I think I damaged the original 211HV Control Module asI am not getting a neg pulse from the green/black or blue/black wires. If I buy a new control module what is the correct procedure to reprogram the current remotes with the new brain?
hf
Platinum - Posts: 13,726
Posted: September 04, 2023 at 4:04 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Page 12
