2008 Honda Civic, Factory Alarm Arm And Disarm Wires?
marfo
Member - Posts: 14
Posted: September 19, 2023 at 5:48 PM / IP Logged Link to Post Post Reply Quote marfo
I am looking at the vehicle wiring information for fitting an alarm to a 08 Honda civic and I am wondering what the factory arm and disarm wires are. Are they not the same as the lock and unlock wires?
Platinum - Posts: 7,827
Posted: September 22, 2023 at 2:39 PM / IP Logged Link to Post Post Reply Quote kreg357
No, different wires. Info below for a U.S. market vehicle, not sure if your Righthand drive vehicle is the same.
OEM Alarm Arm        ORANGE (-)   34 PIN CONN REAR OF FUSE BOX
OEM Alarm Disarm   BROWN (-)    34 PIN CONN REAR OF FUSE BOX
Lock      GREEN   34 PIN CONN, REAR OF FUSE BOX
Unlock   GRAY     34 PIN CONN, REAR OF FUSE BOX
Here is a link to a Pictorial on a 2007 Civic ( 8th Gen 2005 thru 2010 should be similar ). It has a photo of that plug and the wires.
https://www.the12volt.com/installbay/forum_posts.asp?tid=130271
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
