Parasitic Draw After Remote Start Install
tory209
Member - Posts: 24
Posted: October 07, 2024 at 3:02 PM / IP Logged Link to Post Post Reply Quote tory209
I Recently installed an Avital 4105L on a 2001 Silverado LS everything works fine but I noticed if I don't drive the truck for 2 to 3 days it won't start
When I check for a parasitic draw I'm getting .110Ma when using the multimeter. I've read that it should be no higher than .050. When I pull the 10A TBC fuse it drops to .030 The BCM is on this circuit. Further testing shows that when I disconnect the brown plug from the BCM I get the same .030. I feel it may be the 451m module that's causing the draw. Can anyone help.
Tory209
lee.lopez
Copper - Posts: 301
Posted: October 08, 2024 at 3:55 PM / IP Logged Link to Post Post Reply Quote lee.lopez
If you pull the fuse on the 451M does the draw go away? That'll tell you if it's the offender.
tory209
Member - Posts: 24
Posted: October 08, 2024 at 8:26 PM / IP Logged Link to Post Post Reply Quote tory209
When i pull the fuse on the 451 there's no change. I disconnected all power to the R/S and there was no change. Its only when I pull the brown plug on the bcm which contains the lock/unlock relays. I may be dealing with a bad bcm as the guage cluster goes haywire randomly while driving.
Tory209
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
