Diff. question on RS. Pls help!
ziljin
Posted: June 15, 2003 at 7:27 PM / IP Logged
Hi everyone,
   I'm trying to intsall a crimestopper remote starter in a '93 honda del sol si... I'm having problems getting the car to stay on. It'll start for like 3 seconds then shut off... I tried diff. tach. sources, tried timed crank, tach ref and tachless. Nothing is working. I'm thinking it's my wiring.would I need a secone ign. relay? One wire sheet says ign. 2 is yellow , and the acc. is WHITE/ blk, Another wire sheet says the acc. is yellow, and doesn't have a 2nd ign.
Any help would be GREATLY appreciated!
Thanks a bunch,
draasch
Gold - Posts: 2,172
Posted: June 16, 2003 at 4:14 AM / IP Logged
Remote Start
Tach Signal BLUE AT DISTRIBUTOR ASSEMBLY
Ignition #2 YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLACK IGNITION SWITCH HARNES
Neutral Safety GREEN / WHITE GEAR SELECT SWITCH UNDER CONSOLE @ SHIFTER
Brake Light GREEN / WHITE (+) SWITCH ON BRACKET ABOVE BRAKE PEDAL
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
ziljin
Posted: June 16, 2003 at 4:18 AM / IP Logged
Hi david,
Thanks for your reply... It's still not doing anything... Do you know if I need a relay for the 2nd ign? How do I test to find out whether it is - or +?
Thanks again,
Platinum - Posts: 12,488
Posted: June 16, 2003 at 9:09 PM / IP Logged
Did you relearn all the different tach's to the system when you changed them around ?
