Audiovox APS995c won't auto arm?
cherring69
Member - Posts: 10
Posted: June 25, 2003 at 10:40 AM / IP Logged
I believe I've got passive arming enabled on this unit, however I'm not getting the "rapid blinking LED countdown" and it will not auto arm.  Any ideas what it might be?
Thx-
cherring69
Member - Posts: 10
Posted: June 25, 2003 at 10:42 AM / IP Logged
Ooops.  This is on a 2002 F150 SuperCrew...
Chris Luongo
Platinum - Posts: 3,746
Posted: June 26, 2003 at 5:09 PM / IP Logged
It means you have one of your zones is still triggered.....the unit won't arm until it thinks all the doors and trunk are closed.
What are you using for door trigger? If you're using the BLACK/ blue domelight wire, you have to wait for the delayed domelight to go out before the 30 second countdown to begin.
Also, when you arm the alarm manually, do you get three chirps or one? Three chirps means one of the trigger zones is still active.
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
