Factory Alarm
littlet
Posted: June 27, 2002 at 9:20 PM / IP Logged
I put in a Manitis Remote Start/Alarm system in a 1997 Trooper that has a factory alarm that goes off when I Disarm the Mantis.  The factory alarm does not go off when the car has been started and I disarm the car .  Maybe because the car is running and there's no reason for the factory alarm to be engaged???  I know which wire on the factory alarm to disarm the system is but (ORANGE / black) at alarm module but which won from the Mantis System PLEASE HELP
Platinum - Posts: 12,488
Posted: June 27, 2002 at 11:52 PM / IP Logged
Mantis 1200 ?? There is no DISARM wire available on this model. Verify that this is the unit that you have here : http://www.internationalelect.com/mantis7.htm
Chris Luongo
Platinum - Posts: 3,746
Posted: June 28, 2002 at 12:10 AM / IP Logged
I'm not familiar with the Mantis.  But you should be able to split the unit's unlock output with a pair of diodes.  Send one output to the car's unlock wire, and the other to the factory disarm wire.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
