2001 Kia Sephia
Mr_Fusion
Copper - Posts: 113
Posted: July 09, 2003 at 6:36 PM / IP Logged
I am looking for a alarm/remote start diagram for the above. Also, will this car need a door lock actuator in the driver's door for keyless entry?
draasch
Gold - Posts: 2,172
Posted: July 09, 2003 at 7:14 PM / IP Logged
Make:   Kia
Model: Sephia
Year:    2001
This Database Was Last Updated On:    6/9/03
Index #: 2901
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light
Trunk Pin Switch BLUE AT TRUNK LIGHT
Parking Lamp RED / BLACK REAR OF DIMMER
Power Lock
Power Unlock
Information Courtesy Of Installer!! Any Additional Information Appreciated!!
Remote Start
Tach Signal YELLOW/WHITE UNDER RIGHT DASH 25 PIN CONNECTOR
Ignition #2 BLUE/RED IGNITION SWITCH HARNESS
Ignition #3 BLUE/RED IGNITION SWITCH HARNESS
Accessory BLACK/ RED IGNITION SWITCH HARNESS
Neutral Safety
Brake Light GRAY/BLACK AT BRAKE SWITCH
Reverse Light BLUE/BLACK BACK OF INSTRUMENT CLUSTER
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
cpgoose
Gold - Posts: 1,098
Posted: July 10, 2003 at 8:43 AM / IP Logged
If your car doesn't have power door locks, then yes...you'll need an actuator for each door.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
