wiring diagram 2004 Acura TSX
kendoo130
Member - Posts: 11
Posted: July 10, 2003 at 9:09 AM / IP Logged
Going to install a remote start in an Acura TSX-Having a really hard time finding the diagram for this car. Anybody with info will greatly be appreciated.
profuse007
Gold - Posts: 2,015
Posted: July 10, 2003 at 1:07 PM / IP Logged
you probably will have problem finding the diagram. but you can always find it manually and test it. i know you can find these manually:
locks(this might be a pain goin through the door while finding your disarm wire), ignition, acc, starter, brake wire, parkin light (maybe, i know honda have this fuse panel, and right under the panel it has the lil copper metal that you can plug in), tach(honda wont change the blue wire), disarm should be that the door key cylinder, trunk (follow the wire)
as far as the immobilizer they design, i wouldnt know. just hope they dont have something weird.
might not help but thats all i got. good luck
Houston,TX
kendoo130
Member - Posts: 11
Posted: July 10, 2003 at 10:37 PM / IP Logged
profuse thanks for the help-I know I wouldn't have a problem finding the wiring-but the immobilizer is what I am worried about.Don't know which one to use or like you said hope they didn't come up with something weird.I am going to try the one they use on a 2003 RSX and see if I can get it to work.
Ken
Platinum - Posts: 12,488
Posted: July 11, 2003 at 12:26 AM / IP Logged
Use a universal key required module for the Immobilizer system. The one thing you will have to worry about is the OEM disarm for the security system.
kendoo130
Member - Posts: 11
Posted: July 18, 2003 at 8:20 PM / IP Logged
Velocity it worked out fine-Thanks for your suggestion. I caught the disarm wire in the door at the key cylinder.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
