Saturn Vue Keyless Entry
tshooter
Posted: July 10, 2003 at 8:35 PM / IP Logged
I have a 2003 Saturn VUE and would like to find out the easiest way to make the tail lights flash along with the front lights when the vehicle is locked or unlocked with the keyless entry. Thanks in advance for any suggestions/help
Platinum - Posts: 12,488
Posted: July 11, 2003 at 12:49 AM / IP Logged
You can take the 12 volt pulse  that the lock /unlock wire has and run it through two relays. Wire relay like this: http://www.velocitymotorsport.com/images/install_notes/P2P.jpg
Pin 30 output on both relays will go to the parking light wire on the Vue.
tshooter
Posted: July 11, 2003 at 6:49 AM / IP Logged
Thanks but I again have a question. You state to use two relays to accomplish what I want to do. That being the case, and I am truly sorry if I am being dense here, but how would they be wired together and how would they be wired into my vehicle? Thanks again in advance.
Posted: July 11, 2003 at 7:50 AM / IP Logged
Follow the above link to the relay wiring diagram. What this relay does is converts the low current output of the door lock/unlock and boosts it to high current output that the parking lights can use. I say use 2 relays because this will isolate the trigger wires from each other better than if you wanted to use 1 relay with diodes.
tshooter
Posted: July 11, 2003 at 4:27 PM / IP Logged
One last question. The front parking lights already flash with the unlock / lock function of the keyless entry. With the diagram as shown, where would you suggest that I wire in the relay? Thanks again.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
