90 Honda Accord Windows Up?
jsquintz
Member - Posts: 10
Posted: July 14, 2003 at 10:51 PM / IP Logged
Do any of you know where I can find the window wires under the dash (i.e. what color connector they come out of...basic location...etc.) I know they are supposed to be above the drivers kick panel but I can't seem to find em.
10nesne1
Silver - Posts: 284
Posted: July 15, 2003 at 10:57 AM / IP Logged
Here are the wiring colors. Driver's window has to get it from the switch and the others windows that you can get it from Driver's kickpanel.
Good luck
|   LF WINDOW UP/DOWN |RED / yel - RED / blue   | A |drivers door switch        |
|   RF WINDOW UP/DOWN |blu/grn - blu/yel    | A |in drivers door or dkp      |
|   LR WINDOW UP/DOWN |green - grn/yel      | A |in drivers door or dkp      |
|   RR WINDOW UP/DOWN |yel/grn - yellow     | A |in drivers door or dkp      |
Mr.Swifty
Member - Posts: 37
Posted: July 16, 2003 at 1:54 AM / IP Logged
if youre going to get anything at the switch, might as well put the window module in the door and just run wires for the negative trigger
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
