problem with a american accessories alarm
venomdesigns
Posted: July 15, 2003 at 9:20 PM / IP Logged
I have a American Accessories alarm in my car its model as-2pager i have a 2000 acura integra and the thing i can get to work is the keyless entry part.  It has a remote starter in it and the starter will kick on and the engine will turn over but the alarm won't start.  If i turn the key to the on position the car will start and keep starting a few times.  My car does come with transponder keys but with the key sitting in the ignition the car still won't start unless the key is in the on posiotion.  im new to this whole alarm installing process and im completely lossed on why it won't start some please help.
VeNoM
jrilla
Gold - Posts: 1,498
Posted: July 15, 2003 at 9:48 PM / IP Logged
It sounds like you have the accessory and Ignition wires switched. If they are, then the Ignition will drop out during cranking like the accessories are supposed to making it impossible to start. Double check your wiring making sure you plugged the wires into the unit in the correct order.
J Rilla
Owner/Installer
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
