Saturn L200 Remote Start
k2thz
Member - Posts: 23
Posted: July 20, 2003 at 7:10 PM / IP Logged
Hi All-
Thanks for the quick reply on my Intrigue question...
Also working on installing a remote starter in my fiancee's 2001 Saturn L200. It has the 2.2L 4-cylinder...
I have wire colors courtesy of Design Tech intl, but I could use some suggestions on the best way to access the ignition harness. Anyone willing to post a step-by-step?
Thanks,
D. Rea
Rochester, NY
Chris Luongo
Platinum - Posts: 3,746
Posted: July 22, 2003 at 9:13 PM / IP Logged
3 7mm bolts under the steering column, then the column shroud comes off.
You can see the wires there, and they will look impossible to connect to. It is a little difficult, but not impossible.
With everything in place, poke the wires with your meter or test light and test them. Take notes, because during the next step, you won't be able to test them again.
Next, turn the key off and remove it. You can then unplug the ignition wires from the key cylinder, and you'll be able to stretch them down so there's juuuust enough room to work with them.
I'm not sure about what information DesignTech has, but for the L-Series, you have to power up everything----including both the brown and the orange accessory wires---or the climate controls won't operate with remote start. (Actually, I do have a little trick where you don't have to power up the brown wire, if you are comfortable messing around with things.) And don't forget the keysense wire too.
Also, while you can get the parking lights at the steering column too, it's never any fun; there's an easier way. You can get brake and parking lights both in the harness in the driver's kick panel, the harness that runs to the rear of the car.
Also, the Passlock wires are somewhat hidden on this car, but they're there. Imagine yourself looking straight at the keyhole of the ignition switch, and then look at the one o'clock position---that's where the Passlock wires are.
I've done a bunch of the L-Series, so let me know if you need anything else.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|green               |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
| SECOND ACCESSORY|brown               |+ |ignition harness            |
|       POWER LOCK|ORANGE / black        |+ |drivers kick panel          |
|     POWER UNLOCK|RED / black           |+ |drivers kick panel          |
|       LOCK MOTOR|gray               |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |steering column             |
|       HEADLIGHTS|blue *6             |- |steering column             |
|     DOOR TRIGGER|*1                  |- |*2                          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / black           |- |BCM, gray 24 pin plug *2    |
|TRNK/HTCH RELEASE|black               |+ |switch *4                   |
|       TACHOMETER|*3                  |   |*3                          |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|lt blue             |+ |brake switch               |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|green(L), purple(H) |+ |steering column             |
| LF WINDOW UP/DN|dk blue - brown     |A |switch in center console    |
| RF WINDOW UP/DN|blue - brown        |A |switch in center console    |
| LR WINDOW UP/DN|dk green - purple   |A |switch in center console    |
| RR WINDOW UP/DN|lt green - purple   |A |switch in center console    |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|   SUN ROOF LIMIT|not recommended     |   |                            |
|        RADIO 12V|orange              |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|yellow              |+ |radio                      |
| RADIO ILLUMINATE|brown               |+ |radio                      |
|       LF SPEAKER|tan - gray          |   |radio or amplifier *5       |
|       RF SPEAKER|lt green - dk green |   |radio or amplifier *5       |
|       LR SPEAKER|brown - yellow      |   |radio or amplifier *5       |
|       RR SPEAKER|dk blue - lt blue   |   |radio or amplifier *5       |
Notes:
Note: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. Note: The lt. green key sense wire at the steering column must see a ground during remote start to keep the "SERVICE" light from coming on. *1 The drivers door is gray/black. The other doors are BLACK/ white. Both wires are in the gray 24 pin plug at the BCM. Use both wires and diode isolate each. *2 The BCM is located above the glove box. *3 On the 4 cylinder models, use PURPLE / white at the ignition module on the driver side of the motor. On the 6 cylinder models, at the ignition coils on top of the cylinder head on the drivers side of the motor, use any one of the three wires that is not pink or black. *4 Can also use BLACK/ white (+) at the BCM in the gray 24 pin plug. *5 The amplifier in under the driver side dash above the brake pedal. *6 Low beam is high current negative, must use relay.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
