03 Dodge Ram Hemi starter
Greg Shires
Posted: July 24, 2003 at 3:48 PM / IP Logged
Does anyone know where and what color the park/neutral safety wire is?? The vehicle is a 2003 Dodge Ram Quad cab with a Hemi and 5sp. automatic. THANKS
draasch
Gold - Posts: 2,172
Posted: July 24, 2003 at 3:54 PM / IP Logged
Make:   Dodge
Model: Pickup - Fullsize
Year:    2003
This Database Was Last Updated On:    6/9/03
Index #: 49
Alarm
Constant 12 volts PINK/BLACK RED / WHTITE IGNITION SWITCH HARNESS
Ignition 12 volts BLUE 16 gauge IGNITION SWITCH HARNESS *
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light BROWN (-) DRIVER A PILLAR (TECH NOTE)
Trunk Pin Switch
Parking Lamp BLACK / YELLOW (+) AT RELAY BOX UNDER HOOD **
Power Lock WHITE/ DARK GREEN 14 PIN CONNECTOR IN DRIVER #217
Power Unlock SINGLE WIRE SYSTEM KICK PANEL ***
* USE THE SMALL GAGE BLUE WIRE! ** BLACK / YELLOW (+) At Relay Box Under Hood Or At Parking Light. *** WHITE/ DARK GRN Wire Must See Ground Through 820 Ohm Resistor For Lock And Ground Through 330 Ohm Resistor For Unlock.Alt: 220 Ohms. Confermed By More Than One Source The 220 Ohm Worked On Unlock. #217 See Single Wire Resistor Door Lock Circuit Diagram
Remote Start
Tach Signal TAN/RED IGNITION COIL #239
Ignition #2 RED / WHITE 16ga* IGNITION SWITCH HARNESS(TRANS CON)
Ignition #3 DARK GREEN IGNITION SWITCH HARNESS (BLOWER)**
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety
Brake Light WHITE/ TAN AT SWITCH ABOVE PEDAL
Reverse Light VIOLET/BLACK (+) 64 PIN CONNECTOR UNDER HOOD***
Rear Window Defrost
* Also Has Been Noted As RED. **Ignition # 4 : ORANGE Ignition Switch Harness Air Bag Control Module. *** 64 Pin Connector Located On Firewall By Driver Fender VLT/BLK pin # B7 #239- See Transponder By Pass Circuit Diagram If Key is GREY-Vehicle has Transponder, If Key is Black-Vehicle Does Not Have Transponder
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
JWorm
Platinum - Posts: 2,208
Posted: July 24, 2003 at 9:21 PM / IP Logged
Why do you need to use that wire?
draasch
Gold - Posts: 2,172
Posted: July 25, 2003 at 7:03 AM / IP Logged
i have never use the wire on remote starts for the dodge truck. i dont do very many RS units. i not that you will need that wire
Good Luck
David
Ace Security
813-376-9778
Tampa
tjdurham
Copper - Posts: 180
Posted: July 25, 2003 at 11:53 PM / IP Logged
you dont need one just ground your modules neutral safety wire with your ground
tj
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
